air vents in grill assembly
by tarsh » Thu Dec 12, 2013 2:31 am
Have any of u non SS owners tryed making the vents in the grill assembly that allows air through the gap in the middle of the headlight behind the grill? I'm jobless fir the next 3 days so I need a good project. Leme know. Thanks
Take the path less traveled
tarsh
Name: Nathan Schroeder
by mikekey » Thu Dec 12, 2013 8:32 am
Sent you a PM about my secret project. :thumleft:
by HARDTRAILZ » Thu Dec 12, 2013 10:08 am
Not sure what they would add unless you were trying to make a ram air but then you are sort of asking for water to be sucked in.
by tarsh » Thu Dec 12, 2013 11:03 am
More for cooling
tarsh
by HARDTRAILZ » Thu Dec 12, 2013 11:26 am
I see. I thought we had pretty good cooling in stock configuration. Dont really hear of anyone needing to cool the motor. I know the trannys need an extra cooler sometimes, but not sure vents would help.
by mikekey » Thu Dec 12, 2013 11:31 am
HARDTRAILZ wrote:I see. I thought we had pretty good cooling in stock configuration. Dont really hear of anyone needing to cool the motor. I know the trannys need an extra cooler sometimes, but not sure vents would help.
LOL? You are joking right? From the factory we have a fan sized for a 1-ton Duramax and a radiator sized for a 4-banger econobox. It’s very unbalanced. I've seen all kinds of stupid high temperatures from my rig on barely oversized tires.
Although I agree with your statement about the vents. That's a pretty marginal modification.
by tarsh » Thu Dec 12, 2013 11:38 am
Yeah but it's gotta do somthin. More air in is better.
tarsh
by HARDTRAILZ » Thu Dec 12, 2013 11:40 am
I have really only seen high temps once in the mountains before the trans cooler and for a lil time when I had mud packed into the fins of the radiator. Otherwise I have always ran under 220 and these motors like to be about 200-210. Maybe other climates are different.
Seems vents in hood or fenders to remove heat might help more than in the grill. Seems to work well on jeeps.
More air is not always better. Sometimes only so much can be utilized without doing something else.
by tarsh » Thu Dec 12, 2013 11:48 am
That's true I suppose. I don't have a clutch fan, u run just Ann electric and the blaze stays around 200<>190
tarsh
by HARDTRAILZ » Thu Dec 12, 2013 11:54 am
Really....Electrics have been proven over the years not to keep up under rough conditions like the clutch fans do. What setup are you running?
by tarsh » Thu Dec 12, 2013 12:09 pm
Not sure, my neighbor have me one out of his truck. I'll try and find out what it is.And I'll take some pics for ya.it's big, really big. Variable speed options.draws a good amount of power too.
tarsh
by mikekey » Thu Dec 12, 2013 12:27 pm
HARDTRAILZ wrote:I have really only seen high temps once in the mountains before the trans cooler and for a lil time when I had mud packed into the fins of the radiator.
That's about where I seen mine, and out west, up lots of big ass mountain passes and also around here in FL traffic with A/C. Again in Utah, Arizona and Texas with A/C in mostly desert climates and good old Florida. This was before the Transcooler. Have seen better temps in FL traffic with trans cooler. I'm curious to see if that actually solved it for up mountains, can't say yet.
A trans-cooler is probably still a great investment for an item that can be had under $100. :thumleft:
by tarsh » Thu Dec 12, 2013 12:35 pm
I wouldn't know where to begin with one of those.but Probly a good thing for me, seeing as how my trans it's doin the old torque converter slip. Unless it's cold.once it's warm it slips
tarsh
by blazinlow89 » Thu Dec 12, 2013 12:42 pm
I have the grill with the headlight washer holes which allow air through the headlight. I also have the air box gutted.
There was an article on the oos for faux SS grill inserts.
blazinlow89
