Cb radio placement
by Hpimichael02 » Tue Nov 30, 2010 10:20 am
Hey guys I just got a 130$ cb radio for $40 brand new can't beat that, but now it's bigger than I thought and I'm looking for suggestions on where to place this bulky thing
So where do y'all have yours mounted ? And any pics, I know a few of you have a wireless setup and I won't be going the route for now lol
Hpimichael02
by Trail X » Tue Nov 30, 2010 10:43 am
by DmccartneyFF2TB » Tue Nov 30, 2010 9:33 pm
I just got a cb today too!!! im gonna put mine to the right side of the wheel.
Dame
BDS,ROUGH COUNTRY,
Smitty Build XR-C8 Winch
www.wm4x4.com
DmccartneyFF2TB
by Hatchet669 » Tue Nov 30, 2010 11:30 pm
mine just crapped out... gunna get a new cobra... thinking bout installing a new single din radio and in the space left open underneath i'm gunna put the CB... if the new CB i am looking at will work in that position...
Hatchet669
by djthumper » Tue Nov 30, 2010 11:42 pm
Good luck with the single DIN I didn't gain as much as I thought I would when I changed out my head unit.
by wink » Wed Dec 01, 2010 3:36 am
Here is my setup, but it is a smaller radio.
wink ;>
my build
wink
by Hpimichael02 » Wed Dec 01, 2010 8:11 am
Is that the console for the led display?
Hpimichael02
by wink » Thu Dec 02, 2010 3:52 am
It's the whole radio, minus the mic.
wink ;>
my build
wink
by mikepeters1983 » Fri Jan 14, 2011 3:40 am
You could always mount it on the door piller between the drivers side front door and divers side rear door. I for that in the past for me that it makes it easyer to hear, and makes it so that its out of the way on everything, leaving more room for you to put other things every where else.
mikepeters1983
Vehicle: GMC Envoy XUV
DriveTrain: 2WD w/ G80
by HARDTRAILZ » Sun Jan 16, 2011 2:30 am
mikepeters1983 wrote:You could always mount it on the door piller between the drivers side front door and divers side rear door. I for that in the past for me that it makes it easyer to hear, and makes it so that its out of the way on everything, leaving more room for you to put other things every where else.
Good idea if it fits...
by mikepeters1983 » Sun Jan 16, 2011 3:04 am
Well I got the cheap little Corba CB that walmart sells and it really fits there perfect. I would take a pic but that is going to have to wait till I get back home to do that.
mikepeters1983
by KE7WOX » Mon Jan 17, 2011 3:21 pm
It does, however, due to the location of that post, you can't really fold down the rear seat as the radio will prevent it from fitting.
by The Roadie » Mon Jan 17, 2011 3:36 pm
KE7WOX wrote:... can't really fold down the rear seat ...
What is this "rear seat" of which you speak? :woot:
by mikepeters1983 » Mon Jan 17, 2011 3:48 pm
It don't on mine. Its mounted about where the head rest is on the pillar to the left of the drivers seat. I wish I was there to take a pic for you to see and help you understand.
mikepeters1983
by chevycrew » Thu Apr 14, 2011 7:54 pm
Has anyone used the overhead compartment for a CB?
I have the overhead storage compartment, just above the armrest. I have no idea what I would use it for. Im thinking if I pull the door off, my cobra 19DXIII (compact) will fit in there nicely. Also with it up high, it should be easy to hear without running a remote speaker.
Pros, cons, ideas?
by HARDTRAILZ » Thu Apr 14, 2011 8:00 pm
Only neg would be wire hanging down for mic or mic tumbling out in rocky section. I don't have that so I went by driver knee with cobra all in one unit. Works well.
by irishboy02 » Fri Apr 15, 2011 5:56 pm
I have mine mounted to the side of the center console. Where the passengers left knee is. My wires tuck right under and splice into the cig lighter. Have the mic draped across the console to a mount on the dash between the ignition switch and the radio.
2003 GMC Sierra z71
7" FTS lift
irishboy02
by lil_freak_66 » Sun Apr 17, 2011 6:36 pm
i mounted mine pretty much like the first pic JD posted.
only i mounted mine on the passenger side,and the mic holder on the drivers side,works great and required no drilling!
Michigan Search & Rescue.
SARTECH III
lil_freak_66
by Zapp Brannigan » Mon Feb 27, 2012 4:59 am
While not a CB, I did install a Motorola CDM1550LS+, with remote mount head for fire dept use in my TB.
-Unit mounted in the storage area in the right rear cargo area
-Remote head mounted in coin tray in front of shifter, had to notch out the cupholders
-Low Profile UHF Antenna Mounted to roof
Zapp Brannigan
by dvanbramer88 » Mon Feb 27, 2012 10:58 am
see saltwaterdrinker's build thread. mounted it in place of the passenger sun visor retention clip.
Return to Electrical / Radios
