Anyways, on to the pictures!
Surprisingly simple to put together... well, it basically came assembled. You just put on the hook and bolt it to the winch plate (I'm using a curt receiver mounted winch plate).
Close up of the controller. Simple, but effective. Nice rubber bumpers on the left and right to protect the switch too.
Finally a tease of it on the truck. Not wired up or anything, but I at least lugged it over and took a picture for you guys. Again... this thing is a bitch to carry around! I think I've decided I HAVE to get synthetic asap, for the weight issue alone!.
A couple questions... I purchased a 0 gauge Anderson plug (pictured below)... rated to 350 A. But the connectors seem much too large for the wire gauge of the winch. I don't think they'd crimp onto the wires at all. Did I get the wrong sized connector possibly?
Secondly, the kit came with a 150A fuse that apparently you are supposed to put inline with the winch wiring. While I see the reasoning behind this, I thought winches pulled like 300 amps at full power?
I think I'm also going to have to get a new battery in order to even connect the winch. I don't see any obvious way to connect the winch to the stock battery. Or am I just blind?
Outta come in handy this weekend.
